Code Quiz
Q. In general, a disconnecting means is required for each sign and outline lighting system or feeder circuit and branch circuit supplying a sign or outline lighting system per 600.6. When is a disconnecting means not required per 600.6? When the sign ...
April 13, 2007
  1. When the sign is an exit directional sign supplied by batteries.
  2. When the sign is cord-connected with an attachment plug.
  3. When the sign is an exit directional sign located within a building.
  4. Both B and C.
Answer: D
Exception No. 1 and Exception No. 2 of 600.6 permit the disconnecting means to be omitted.
