The requirements for photovoltaic systems (PV) system disconnects were almost entirely rewritten with the 2017 revision of the National Electrical Code (NEC). If you just got comfortable with the revised requirements, you might not be thrilled that it's déjà vu all over again with the 2020 revision.
One goal is to protect unqualified persons from the system and vice versa. We find this new disconnect requirement in two places:
“Where disconnecting means of systems above 30V are readily accessible to unqualified persons, any enclosure door or hinged cover that exposes live parts when open shall be locked or require a tool to open.”
You'll find it in reference to the PV system disconnecting means [Sec. 690.13(A)] and in reference to the disconnecting means for PV equipment [Sec. 690.15(A)]. So basically, the cover of a disconnect in a PV system must not be easily opened by an unqualified person.
The 2020 revision also requires these disconnects to be lockable [Sec. 690.13(E)] and [Sec. 690.15(C)].
The system disconnect must simultaneously disconnect all conductors that are not solidly grounded [Sec. 690.13(E)], while equipment disconnects must simultaneously disconnect all current-carrying conductors that are not solidly grounded [Sec. 690.15(C)].
Mark LamendolaMark Lamendola
