Article 691 of the 2020 National Electrical Code (NEC) provides the requirements for large-scale photovoltaic (PV) supply stations that are not under exclusive electric utility control. Where exactly does “large scale” begin? At 5,000kW [Sec. 691.1]. And what is meant by an electric supply station? It's a location containing the generating station(s) and substation(s), including associated generator, storage battery, transformer, and switchgear areas [Sec. 691.2].
These stations must meet the “special requirements” of Sec. 691.1(1) through (5). The fifth requirement is one of their distinguishing characteristics: they cannot be installed on buildings.
These installations are to have an engineered design. Accordingly, your workflow should include having an independent licensed professional electrical engineer review and stamp the drawings and other documentation of the electrical portion. If the authority having jurisdiction (AHJ) asks for this stamped documentation and you cannot provide it, your project likely will not be approved [Sec. 691.6].
To get approval to operate, you also need to document that construction proceeded per plan (to the engineered design, anyhow) [Sec. 691.7]. Just as a professional engineer (P.E.) is integral to documenting the design, a P.E. is integral to documenting the construction conforms to the design.
Mark LamendolaMark Lamendola
