An NEC Crash Course to Get You Started — Part 2
It is a mistake to consider Art. 100 something you need only if you don’t understand a particular term.
The NEC has grown organically since inception. Initially, it was not much more than a pamphlet. Now it is more than 900 pages in the loose-leaf version. The fact it is organized at all is testament to the hard work, dedication, and foresight of the code-making panels.
The NEC has grown over the years because it is a continuous work in progress (even between revision cycles), adapting to changes in methods, materials, and applications. Try to imagine a Rip Van Winkle NEC expert who awakens after 21 years (seven code cycles). That person would have a lot of studying to do to become an expert again, yet he would not be completely lost because the structure of the NEC would not have changed much.
Rip should start with Art. 90, which gives a good overview. However, he would probably start with Art. 100 to catch up on new definitions. It is a mistake to consider Art. 100 something you need only if you don’t understand a particular term — because it’s unlikely you know that you misunderstand it.
