An NEC Crash Course to Get You Started — Part 4
The importance of Informative Annex D.
Parts of Chapter 2 provide the requirements for services, feeders, and branches. Parts of Chapter 3 tell you how to size conductors. How can you put all of this together for an actual application or to solve a problem on an electrical license exam? Doing either one accurately and efficiently takes practice, but to get the feel of how these requirements work together there is a solution right in the NEC.
It’s called Informative Annex D. It contains examples of various kinds of problems you might solve in the field or on an exam. While the level of explanation is less than what you’d have with a structured program of study, it is nonetheless very helpful for nailing down the concepts.
If you walk through Example D3 (Store Building), you will cover the major steps for calculating the loads, sizing the conductors, and sizing the overcurrent protection for most commercial applications. If your applications are primarily industrial, then you will also want to walk through Example D3(a).
