An NEC Crash Course to Get You Started — Part 5
Understanding and correctly applying Art. 250 of Chapter 2
Article 250 of the National Electrical Code (NEC) is arguably the most difficult Chapter 2 article to understand and correctly apply. One reason is that people often approach it without knowing the difference between grounding and bonding. If you read the definitions in Art. 100, you will see that grounding means you connect it to the earth, and bonding means you create a metallic path back to the source. With this in mind, you can see that driving a ground rod next to a motor simply wastes a ground rod.
Another reason people get confused and end up with unsafe installations is this notion that electricity takes the path of least resistance. Is this true? On paper, draw a simple circuit with two resistors in parallel. One is 100 Ω, the other is 500 Ω. Do you think all of the electricity flows through the 100-Ω resistor? If you solve each parallel branch for current, you will see that five-sixths of it flows through the 100- Ω resistor, and one-sixth through the 500-Ω resistor.
