Code Q&A
Q. What does the NEC require when replacing receptacles in locations that now require arc fault circuit interrupter (AFCI) protection?
May 5, 2011
A. Effective Jan. 1, 2014, where a receptacle outlet is supplied by a branch circuit that requires arc-fault circuit-interrupter protection [210.12(A)], a replacement receptacle at this outlet must be one of the following [406.4(D)(4)]:
  1. A listed (receptacle) outlet branch circuit type arc-fault circuit-interrupter receptacle.
  2. A receptacle protected by a listed (receptacle) outlet branch circuit type arc-fault circuit-interrupter type receptacle.
  3. A receptacle protected by a listed combination type arc-fault circuit interrupter type circuit breaker.
Mike Holt
Mike Holt
