Q. Is GFCI protection required for a sump pump installed in an unfinished basement of a dwelling unit?
A. GFCI protection is required for all 15A and 20A, 125V receptacles located in the unfinished portion of a basement not intended as a habitable room and limited to storage and work areas [210.8(A)(5)].
Exception: A receptacle supplying only a permanently installed fire alarm or burglar alarm system isn’t required to be GFCI protected [760.41(B) and 760.121(B)].
Note: A receptacle outlet is required in each unfinished portion of a dwelling unit basement [210.52(G)].
Mike HoltMike Holt
