Code Q&A: Portable Cords
NEC rules on portable cords for permanent wiring
Q. What is the Code rule regarding using portable cords for permanent wiring?
Underlined text indicates a change in the rules for the 2017 NEC.
A. Unless specifically permitted in Sec. 400.10, flexible cords sets (extension cords) and power‑supply cords aren’t permitted for the following [400.12]:
(1)  Flexible cord sets (extension cords) and power‑supply cords aren’t permitted to be a substitute for the fixed wiring of a structure.
(2)  Flexible cord sets (extension cords) and power‑supply cords aren’t permitted to be run through holes in walls, structural ceilings, suspended or dropped ceilings, or floors. (Figure)
(3)  Flexible cord sets (extension cords) and power‑supply cords aren’t permitted to be run through doorways, windows, or similar openings.
(4)  Flexible cord sets (extension cords) and power‑supply cords aren’t permitted to be attached to building surfaces.
(5)  Flexible cord sets (extension cords) and power‑supply cords aren’t permitted to be concealed by walls, floors, or ceilings, or located above suspended or dropped ceilings.
Exception to (5): Flexible cords can be located above suspended or dropped ceilings if installed in a metal enclosure in accordance with Sec. 300.22(C)(3).
(6)  Flexible cord sets (extension cords) and power‑supply cords aren’t permitted to be installed in raceways, except as permitted by Sec. 400.17 for industrial establishments where the conditions of maintenance and supervision ensure that only qualified persons will service the installation.
(7)  Flexible cord sets (extension cords) and power‑supply cords aren’t permitted where they’re subject to physical damage.
Even cords listed as “extra‑hard usage” must not be used where subject to physical damage.
These materials are provided to us by Mike Holt Enterprises in Leesburg, Fla. To view Code training materials offered by this company, visitwww.mikeholt.com/code
Mike Holt
Mike Holt
