Code Q&A: Flexible Cord Requirements for Appliances
When does the NEC permit the connection of appliances using flexible cords?
Courtesy of www.MikeHolt.com.
Q. When does the NEC permit the connection of appliances using flexible cords?
See answer below.
A. Flexible cords are permitted for appliances when needed for [Sec. 422.16(A)]:
(1)  Facilitating frequent interchange, or preventing the transmission of noise and vibration [Sec. 400.10(A)(6) and (7)].
(2)  Facilitating the removal of appliances fastened in place, where the fastening means and mechanical connections are specifically designed to permit ready removal [Sec. 400.10(A)(8)].
Author’s Comment: Flexible cords are not permitted for the connection of water heaters, furnaces, and other appliances fastened in place unless the appliances are specifically identified to be used with a flexible cord.
Russ LeBlanc
Russ LeBlanc
