Code Q&A: Ground-Fault Detection of Storage Battery Circuits
Test your knowledge of the NEC.
May 25, 2022
Courtesy of www.MikeHolt.com
All questions and answers are based on the 2020 NEC.
Q. What is the NEC requirement for ground-fault detection of storage battery circuits?
See answer below.
A. Battery circuits exceeding 100V between the conductors or to ground are permitted to operate with ungrounded conductors, provided a ground-fault detector and indicator is installed to monitor for ground faults [Sec. 480.13].
Mike Holt
Mike Holt
