Code Q&A: Connecting Equipment Grounding Conductor Contacts
Courtesy of www.MikeHolt.com. Based on the 2023 NEC.
Question: Receptacles and cord connectors that have equipment grounding conductor contacts shall have those contacts connected to _____.
a) the enclosure
b) a bonding bushing
c) an equipment grounding conductor
d) any of these
See answer below.
Answer: c) an equipment grounding conductor
Per Sec. 406.4(C): "The equipment grounding conductor contacts of receptacles shall be connected to an equipment grounding conductor of the circuit supplying the receptacle in accordance with Sec. 250.146."
Mike Holt
Mike Holt
