Code Quiz
When connecting a surge protective device (SPD) grounding conductor of a Type 1 SPD at the service, which of the following connections is permitted? Note: the SPD may be a surge arrester or TVSS
Q. When connecting a surge protective device (SPD) grounding conductor of a Type 1 SPD at the service, which of the following connections is permitted? Note: the SPD may be a surge arrester or TVSS.
  1. Equipment grounding terminal in the service equipment.
  2. Grounding electrode for the service.
  3. Grounding electrode conductor.
  4. Grounded service conductor
  5. All of the above are permitted.
Answer: E
As per 285.23(B) of the 2008 NEC, any of the above mentioned methods are considered an acceptable installation.
