Code Quiz
Per 250.190(C), when installing 5kV-rated, metallic insulation shielded, current-carrying conductors, is it permitted to use the metallic tape insulation shield and drain wire as an equipment grounding conductor for a solidly grounded system?Note: The metallic insulation shield encircles the conductor.
