Code Quiz
Which of the following ballasts are required to have thermal protection?
  1. The ballast of a fluorescent luminaire installed indoors, including a replacement ballast for this type of luminaire
  2. A simple reactance ballast in a fluorescent luminaire with straight tubular lamps
  3. A ballast in a fluorescent exit luminaire
  4. A ballast in a fluorescent luminaire used for egress lighting, and energized only during a failure of the normal supply
  5. All of the above
Answer: A
The special provisions for electric-discharge lighting systems of 1,000V or less can be found in Part XII of Art. 410. As noted in 410.130(E), "The ballast of a fluorescent luminaire installed indoors shall have integral thermal protection. Replacement ballasts shall also have thermal protection integral with the ballast."
A simple reactance ballast in a fluorescent luminaire with straight tubular lamps, a ballast in a fluorescent exit luminaire, and a ballast in a fluorescent luminaire used for egress lighting and energized only during a failure of the normal supply are not required to have thermal protection.
