Code Quiz: Outdoor Luminaire Location
When installing outdoor luminaires, you must place the fixtures below all energized conductors, transformers, or other electric utilization equipment, unless _________ .
Fill in the blank with the appropriate answer.
A. Clearances or other safeguards are provided for re-lamping operations
B. Equipment is controlled by a disconnecting means that can be locked in the open position
C. Either A and B
D. Both A or B
Answer: C
As per Section 225.25 of the 2011 NEC, you must meet one of the requirements noted above (i.e., either A or B). The intent of this rule is to make it safe for someone to re-lamp the outdoor luminaire.
