Code Quiz: Door Stops and Cover Plates
NEC rules for positioning external hinged doors or covers when installing metal-clad power switchgear (over 600V).
Dec. 6, 2012
Fill in the blank with the appropriate answer.
When installing metal-clad power switchgear (greater than 600V), the external hinged doors or covers must be  ___________ .
A. provided with stops to hold them in the open position
B. provided with a full-length hinge
C. lockable.
D. provided with a viewing window
Answer: A
To be compliant with Section 490.38 of the 2011 NEC, when installing metal-clad power switchgear (greater than 600V) the external hinged doors or covers must be provided with stops to hold them in the open position.
