Code Quiz: Neutral Conductor Installation Requirements
NEC requirements for installing neutral conductors
Dec. 5, 2013
Fill in the blank with the appropriate answer.
Disregarding exceptions, where more than one neutral conductor associated with different circuits is in an enclosure, grounded circuit conductor(s) of each circuit shall be identified or grouped to correspond with the ungrounded circuit conductor(s) by methods such as ______________ in at least one location within the enclosure.
A. wire markers
B. cable ties
C. similar means
D. all of the above
Answer: D
It is important to identify the appropriate neutral conductor associated with the ungrounded conductor(s) for any circuit, especially for personnel who install and maintain electrical circuits and equipment. Section 200.4(B) in the 2014 edition of the NEC was revised to provide information on how to accomplish this and make the work safer for personnel working with circuits and equipment.
