Code Quiz: Service Masts as Supports
NEC rules on using service masts as supports
March 6, 2014
Fill in the blank with the appropriate answer.
When installing a service mast, the hubs used with the conduit that serve the service mast shall be _____________.
  1. any type of hub.
  2. identified for use with service-entrance equipment.
  3. identified for use with feeder conductors.
  4. listed for grounding.
The correct answer is: 2) identified with use for service-entrance equipment
Section 230.28(A) of the 2014 NEC requires hubs to be identified for use with service-entrance equipment.
