Code Quiz: Definition of Voltage to Ground
What does voltage to ground really mean?
As per the definition in Art. 100 of the 2014 NEC, what is the voltage to ground value on a circuit in a 480V ungrounded system.
A)  240VAC
B)  277VAC
C)  480VAC
D)  208VAC
Answer: C
For ungrounded circuits, “voltage to ground” is defined as “the greatest voltage between the given conductor and any other conductor of the circuit.”
