Code Quiz: Definition of Hermetic Refrigerant Motor Compressor
NEC guidelines on refrigerant motor compressors
A hermetic refrigerant motor compressor consists of a compressor and motor, both of which must be enclosed in _____  ______  ______, with no external shaft or shaft seals, with the motor operating in the refrigerant.
A)  the same housing
B)  suitable rigid housing
C)  metallic housing enclosure
Answer: A
A hermetic refrigerant motor compressor is defined in Art. 100 of the 2014 NEC as a combination of a compressor and motor, both of which are enclosed in the same housing, with no external shaft or shaft seals, with the motor operating in the refrigerant.
