Code Quiz: Approved Wiring Methods in Marinas and Boatyards
NEC guidelines on wiring methods for boatyards and marinas
Fill in the blank with the appropriate answer.
With respect to wiring methods and materials for marinas and boatyards, when using portable power cables, the power cables shall be rated not less than ___ , and listed for both wet location and sunlight resistance as part of the overall requirements?
A) 75°C / 600V
B) 75°C / 300V
C) 60°C / 600V
D) 90°C / 600V
Answer: A
As noted in Sec. 555.13(A)(2), “When using portable power cables in marinas and boatyards, the power cables shall be rated not less than 75°C / 600V, and listed for both wet location and sunlight resistance; and having an outer jacket rated to be resistant to temperature extremes, oil, gasoline, ozone, abrasion, acids, and chemicals.”
