Code Quiz: Boxes and Faceplates
NEC guidelines on installing boxes and faceplates.
Aug. 5, 2015
Fill in the blank with the appropriate answer.
Faceplates provided for snap switches mounted in boxes shall be installed so as to _________ cover the opening, and where the switch is flush mounted, seat against the finished surface. Any gaps or open spaces at the edge of a box installed in a non-combustible surface shall be repaired if _________.
A) completely / if the gap is greater than 1/8 in.
B) formally / if the gap is greater than ¼ in.
C) be conductive and / not required if using a “jumbo” plate that completely covers  the opening
D) be nonconductive and / there is no requirement for repairing around boxes
Answer: A
As noted in Sec. 404.9(A), “Faceplates provided for snap switches mounted in boxes shall be installed so as to completely cover the opening and where the switch is flush mounted, seat against the finished surface.”
As per Sec. 314.21, “Any gaps or open spaces at the edge of a box installed in a non-combustible surface shall be repaired if the gap is greater than 1/8 in.”
