Code Quiz: Proper Installation of an Isolated Ground Receptacle
NEC guidelines on proper installation of an isolated ground receptacle
Fill in the blank with the appropriate answer.
Isolated ground receptacles installed in nonmetallic boxes shall be covered with a _________.
A) nonmetallic faceplate
B) metal faceplate if the box contains a feature or accessory that permits the effective grounding of the faceplate
C) either A or B are allowed
D) neither A nor B is allowed
Answer: C
As noted in Sec. 406.3(D)(2), isolated ground receptacles installed in nonmetallic boxes shall be covered with a  nonmetallic faceplate or (by Exception) a metal faceplate if the box contains a feature or accessory that permits the effective grounding of the faceplate.
