Code Quiz: GFCI Protection for Personnel
NEC rules on GFCI protection
With respect to locations listed in Art. 620, and as listed in (A) through (D) below, which is the only location where 15A and 20A, 125V, single-phase receptacles may be installed without GFCI protection?
A) in an escalator
B) a single receptacle for a sump pump
C) in the pit
D) on elevator car tops
Answer: B
As noted in the third paragraph of Sec. 620.85 in the 2014 NEC, “A single receptacle supplying a permanently installed sump pump shall not require ground fault circuit interrupter protection for personnel.”
