• Code Quiz: Sizing EGCs
    NEC requirements for sizing equipment grounding conductors
    May 5, 2016
    When installing branch circuits for artificial bodies of water, such as municipal infrastructure, what is the minimum size (copper) equipment grounding conductor required for a 15A, 120V circuit?
    A) 14 AWG
    B) 12 AWG
    C) 10 AWG
    D) 8 AWG
    Answer: B
    Article 682 applies to the installation of electrical wiring for natural or artificially made bodies of water not covered by other Articles in the Code. Under normal circumstances, a 14 AWG (copper) equipment grounding conductor would be acceptable as per Sec. 250.122. However, as specifically noted in Sec. 682.31(A), the EGC shall not be smaller than 12 AWG.
    Steven Owen
