Code Quiz: Submersible or Floating Equipment Power Connection(s)
NEC requirements on when it is permissible to disconnect submersible or floating electrical equipment from its supply by means of cord and plug connection
With respect to natural and artificially made bodies of water (excluding exceptions), when is it permissible to disconnect submersible or floating electrical equipment from its supply by means of cord and plug connection?
A) When the receptacle is twist-lock type.
B) When the receptacle is GFCI protected.
C) When the receptacle is a GFCI-type receptacle.
D) It is not permitted.
Answer: D
Article 682 applies to the installation of electrical wiring for natural or artificially made bodies of water not covered by other Articles in the Code. As noted in Sec. 682.14, a disconnecting means shall be provided to isolate each submersible or floating electrical equipment from its supply connection(s) without requiring the plug to be removed from the receptacle.
Owen is the owner and president of National Code Seminars and the holder of master electrician certifications in 46 states. He can be reached at [email protected].
