Code Quiz: Suspended-Ceiling, Low-Voltage, Power-Grid Distribution Systems
NEC requirement for grounding the load side circuits for suspended ceiling low-voltage power grid distribution systems that are supplied by a Class 2 power source
What is the requirement for grounding the load side circuits for suspended ceiling low-voltage power grid distribution systems that are supplied by a Class 2 power source?
A) Install a 16 AWG equipment grounding conductor in every circuit.
B) Install a 14 AWG equipment grounding conductor in every circuit.
C) Install a 12 AWG equipment grounding conductor in every circuit.
D) The load side circuits shall not be grounded.
Answer: D
As noted in Sec. 393.60(B), the load side circuits shall not be grounded.
