Code Quiz: Restricted Access for Adjustable-Trip Circuit Breakers
NEC requirements for restricted access
When dealing with adjustable-trip circuit breakers, “restricted access” is defined as?
A) Located behind removable and sealable covers over the adjusting means
B) Located behind bolted equipment enclosure doors
C) Located behind locked doors accessible only to qualified personnel
D) A, B or C
Answer: D
When dealing with adjustable-trip circuit breakers, restricted access is defined in Sec. 240.6(C) of the 2014 NEC as: “located behind one of the following: removable and sealable covers over the adjusting means; bolted equipment enclosure doors; locked doors accessible only to qualified personnel.”
