Code Quiz: Permanent Barriers
NEC requirements for permanent barriers
Fill in the blank.
Where permanent barriers are installed in a box, each section shall be considered as a ______ ______.
A) wiring enclosure
B) grounded enclosure
C) separate box
D) none of the above
Answer: C
Part II of Art. 314 covers the installation requirements for boxes. As specifically stated in Sec. 314.28(D), “Where permanent barriers are installed in a box, each section shall be considered as a separate box.”
