Code Quiz: Lighting Outlet Requirements
NEC lighting requirements for storage spaces
Fill in the blanks.
For attics and underfloor spaces, ________, and _______, at least one lighting outlet containing a switch or controlled by a wall switch shall be installed where these spaces are used for storage or contain equipment requiring servicing. This applies to ________.
A) utility rooms / basements / only to commercial occupancies
B) ceiling cavities / cellars / only to dwelling units
C) utility rooms / basements / all occupancies
Answer: C
As specifically outlined in the opening sentence of Sec. 210.70(C) of the 2017 NEC, “For attics and underfloor spaces, utility rooms, and basements, at least one lighting outlet containing a switch or controlled by a wall switch shall be installed where these spaces are used for storage or contain equipment requiring servicing.” This applies to all occupancies.
