Code Quiz: Elevator Wiring Methods
NEC requirements for elevator counterweight assembly
Which of the following wiring methods, per Sec. 620.21(A)(4), is permitted on the  elevator counterweight assembly?
A) Flexible metal conduit
B) Liquid flexible metal conduit
C) Liquid flexible nonmetallic conduit
D) Flexible cords and cables, or conductors grouped together and taped or corded
E) All the above are permitted
Scroll Down for the Answer
Answer: E
As noted in Sec. 620.21(A)(4), the following wiring methods are permitted in an elevator hoistway:
(1) Flexible metal conduit
(2) Liquidtight flexible metal conduit
(3) Liquidtight flexible nonmetallic conduit
(4) Flexible cords and cables, or conductors grouped together and taped or corded, shall be permitted to installed without a raceway.
