Code Quiz: Grounding of Motors, Motor Circuits and Controllers
When grounding exposed non-current-carrying metal parts of motors and controller frames to prevent a voltage above ground in the event of accidental contact between energized parts and frames, what are suitable alternatives to grounding of motors under certain conditions?
A) Insulation
B) Isolation
C) Guarding
D) All of the above
Scroll Down to See Answers
Answer: D
Article 430 of the 2017 NEC focuses on motors, motor circuits and controllers. Part XIII of this Article covers the grounding requirements for all voltages. As per Sec. 430.241, “Part XIII specifies the grounding of exposed non-current-carrying metal parts, likely to become energized, of motor and controller frames to prevent a voltage aboveground in the event of accidental contact between energized parts and frames. Insulation, isolation, or guarding are suitable alternatives to grounding of motors under certain conditions.”
