Code Quiz: Working With Adjustable Luminaires
On luminaires that require adjusting or aiming after installation
Luminaires that require adjusting or aiming after installation shall not be required to be equipped with an attachment cap or cord connector, provided the exposed cord is _________ for hard-usage or extra hard-usage and is not longer than that required for maximum adjustment. The cord shall not be exposed to strain or physical damage.
A) listed
B) identified
C) suitable
D) marked
See the answer below.
Answer: C
Section 410.62 of the 2017 NEC focuses on cord-connected lampholders and luminaires.
As specifically outlined in 410.62(B), “Luminaires that require adjusting or aiming after installation shall not be required to be equipped with an attachment cap or cord connector, provided the exposed cord is suitable for hard-usage or extra hard-usage and is not longer than that required for maximum adjustment. The cord shall not be exposed to strain or physical damage.”
