Code Quiz: Sources of Power – Unit Equipment
Learn the NEC requirements on dedicated circuits.
Question: To facilitate testing of emergency lighting unit equipment required by Sec. 700.3, is it permissible to place all emergency lighting unit equipment on a separate dedicated circuit?
See the answer below.
Answer: No.
Explanation: Section 700.12(F) specifically forbids placing unit equipment on a separate circuit. The unit equipment is intended to provide lighting in the event of failure of the normal source. One common failure of the normal source would be tripping of the branch circuit feeding the lights. In this case, if the unit equipment is on a circuit by itself it will not come on when the lights go out.
John Lupacchino
Senior Design Engineer
