Code Quiz: Temporary Power Requirements
See if you can answer this true or false statement.
True or False?
Statement: Temporary power is limited to 90 days in duration.
See the answer below.
Answer: False
Explanation: The 90-day limit is only for holiday decorative lighting and similar purposes. There is no specific time limit for temporary power installed for construction or emergencies and tests. However, all temporary wiring must be removed immediately upon completion of the purpose for which it was installed (Sec. 590.3).
John Lupacchino
Senior Design Engineer
