True or False?
Statement: Residential clothes dryer receptacles require GFCI protection.
See the answer below.
Answer: True
Explanation: A 2020 NEC change now requires all 125V through 250V receptacles located in the areas specified in Sec. 210.8(A)(1) through (11) to have GFCI protection. The previous edition of the NEC only required 125V receptacles to have GFCI protection.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
John Lupacchino
Senior Design Engineer
Related
Wiring job
