Based on the 2020 NEC.
True or False?
Question: Per NEC requirements, a single-family dwelling requires an exterior means to disconnect power.
See the answer below.
Answer: True
Explanation: A new Section 230.85 [Emergency Disconnects] requires that one- and two-family dwellings have the service conductors terminate in an exterior disconnecting means. This disconnect can be a service disconnect, a meter disconnect, or other listed disconnect means on the supply side of the service disconnect. Disconnects shall be marked per the requirements listed in 230.85 and in compliance with Sec. 110.21(B).
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
John Lupacchino
Senior Design Engineer
