Code Quiz: Special Provisions for Flush and Recessed Luminaires
Based on the 2020 NEC.
True or false?
Statement: A 2 ft x 4 ft recessed luminaire can be used to provide access to pull or junction boxes located in the ceiling above the luminaire.
See the answer below.
Answer: False
Explanation: A new requirement in the 2020 NEC (Sec. 410.118) prohibits the use of a recessed luminaire to access boxes that are not an integral part of the listed luminaire.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
John Lupacchino
Senior Design Engineer
