Code Quiz: NEC Requirements for Sump Pumps
Can you answer this challenging Code quiz?
Question: True or False? A sump pump is required to have GFCI protection.
See the answer below.
Answer: True
Explanation: In the 2020 NEC, sump pumps were added to the list of appliances in Sec. 422.5(A) that require GFCI protection. The requirement applies to all sump pumps rated 150V or less to ground and 60A or less.
John Lupacchino
Senior Design Engineer
