Code Quiz: Code-Approved Switching Devices
Test your NEC knowledge with this quiz.
Based on the 2020 NEC.
Question: Can a line voltage thermostat serve as a disconnecting means for electric baseboard heat?
 See answer below.
Answer: Yes
Explanation: Section 424.20(A) in the 2020 NEC permits thermostatically controlled switching devices to be used as a disconnect means if they meet five conditions:
  • It has a marked OFF position
  • Directly opens all HOT conductors in the OFF position
  • Designed so the circuit cannot be energized automatically after the device is placed in the OFF position
  • Located within sight of the baseboard heater
  • Located in an accessible location (new requirement for 2020 NEC)
John Lupacchino
Senior Design Engineer
