Code Quiz: Meter-Mounted Transfer Switches
Test your knowledge of the NEC.
Question: Can a meter-mounted transfer switch be used in an emergency system?
Answer: No
See answer below.
Explanation: A new sentence was added to the 2020 NEC [Sec. 700.5(A)], which reads as follows: "Meter-mounted transfer switches shall not be permitted for emergency system use."
John Lupacchino
Senior Design Engineer
