Code Quiz: Workspace Requirements
Test your Code knowledge.
Based on the 2020 NEC.
True or False: The minimum 30 in. width of the workspace specified in Sec. 110.26 must be centered on the equipment.
See answer below.
Answer: False
Explanation: Section 110.26(A)(2) requires a 30 in. minimum workspace or the width of the equipment, whichever is greater, and the door must be able to open 90°. There is no requirement that the equipment must be centered in the space.
John Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
John Lupacchino
Senior Design Engineer
