Code Quiz: Emergency Stop Button – Yes or No?
Based on the 2020 NEC.
Question: Does a generator require a remote emergency stop button?
See answer below.
Answer: Yes
Explanation: Section 445.18(C) of the 2020 NEC requires a remote emergency stop button to be located outside the equipment room or generator enclosure for all generators rated greater than 15kW.
John Lupacchino
Senior Design Engineer
