Based on the 2020 NEC.
Question: True or false? Temporary wiring can only be installed for a maximum of 90 days.
See answer below.
Answer: False
Explanation: Section 590.3 of the 2020 NEC specifies the time constraints for temporary wiring. Temporary wiring is allowed for the period of construction or remodeling with no time limit. Temporary wiring is allowed for a period of 90 days for holiday decorative purposes. Temporary wiring is allowed for emergencies, tests, and developmental work without a time constraint. All temporary wiring is to be removed immediately after construction completion or the purpose for which it was installed.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
John Lupacchino
Senior Design Engineer
Related
quiz notebook
