Based on the 2023 NEC.
Question: True or false? In a dwelling unit kitchen, a single receptacle located behind the refrigerator would not require GFCI protection if it is fed from a dedicated circuit.
See answer below.
Answer: False
Explanation: Section 210.8 (A)(6) applies to ALL receptacles 125V through 250V single phase 150V or less to ground, this would include the receptacle for the refrigerator even though it is not readily accessible. The 2020 Code requirement was only for receptacles that served the countertop surfaces, which would not include the receptacle behind a refrigerator.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected].
John Lupacchino
Senior Design Engineer
Related
quiz tiles on yellow background
pencil writing a question mark
