Based on the 2023 NEC.
Question: What is the classification of an outdoor area 16 ft from a gasoline dispensing pump?
See answer below.
Answer: Class 1 Division 2
Explanation: NEC Table 514.3(B)(1) lists the area up to 18 in. above grade extending 20 ft horizontally in all directions as Class 1 Division 2.
Lupacchino is a senior design engineer with Gaylor Electric, Inc. in Noblesville, Ind. and serves as an alternate on NEC Code-Making Panel No. 3. He is currently licensed in more than 80 jurisdictions. He can be reached at [email protected]
John Lupacchino
Senior Design Engineer
