Power Quality & Energy Monitoring in Controlled Environment Agriculture
Key Takeaways
- CEA facilities require reliable, clean power to maintain precise environmental controls for high-value crops.
- Power quality issues like harmonic distortion, voltage sags, and outages can disrupt operations and damage equipment, risking crop loss.
- Installing a permanent power quality monitor provides real-time data, waveform analysis, and energy profiling to identify and address power disturbances proactively.
- Continuous monitoring enhances decision-making, improves energy efficiency, and reduces downtime, ensuring optimal crop growth conditions.
Controlled environment agriculture (CEA) relies on advanced technologies such as climate control systems, artificial lighting, and hydroponic or aeroponic growing systems. These systems, in turn, require stable, clean power. This case study outlines how a New Jersey-based indoor farming facility addressed persistent HVAC and VFD failures by installing a permanent power quality and energy meter along with master monitoring station. The meter and station setup provided insight into utility feed conditions, helped diagnose internal power events, and offered actionable data to prevent crop loss.
Indoor cultivation requires reliable power
CEA facilities typically aren’t simple greenhouses. Rather, they’re high-density industrial spaces that replicate ideal outdoor conditions, including temperature, humidity, airflow, and CO₂ levels — and they must do it 24/7 to protect high-value crops. Such a facility includes:
• High-intensity lighting systems
• HVAC systems tailored for tight humidity and temperature control
• Dehumidifiers and reheat coils
• Irrigation pumps
• CO₂ emitters
• Fans for air movement
• Automated environmental monitoring and controls
Each of these systems draws significant power. In fact, some indoor horticulture operations can use up to 10 times more energy per square foot than a typical office building.
The electrical load behind the CEA facility
Keeping a CEA facility running often requires electrical engineering expertise as much as horticultural smarts.
Lighting, HVAC, and environmental control systems often run on dedicated circuits and variable-frequency drives (VFDs) to maintain efficiency. Many facilities also operate with year-round HVAC cycles — meaning cooling and dehumidification don’t stop, even in winter. Key electrical demands include:
- Continuous operation of HVACD (Heating, Ventilation, Air Conditioning, Dehumidification) systems
- High-wattage lighting (e.g., LED or HID systems)
- CO₂ delivery and sensor systems
- Centralized control systems and security monitoring
As a result, CEA facilities can be major utility customers. Energy usage can reach 16,000kWh per day for mid-size operations.
Common power quality challenges
With this level of electrical demand, it’s clear that power quality can directly impact yield, product quality, and profit margins. Even minor disturbances in power quality can disrupt operations — and that’s exactly what started happening at the New Jersey facility.
Power quality risks in CEA operations can include:
- Harmonic distortion caused by LED drivers and VFDs, leading to overheating and potential equipment failure.
- Voltage sag or drop, especially during load start-up events.
- Power interruptions. Even brief outages can stress environmental control systems, leading to inconsistent grow conditions or system lockouts.
- Grid impact from load density. In regions where multiple, large energy consuming sites operate within the same utility zone, the collective demand can stress local distribution systems, causing grid instability and the potential for increased power outages.
At the N.J. facility, the HVAC system and VFDs began failing unexpectedly, threatening their high-value crops. Without clean, consistent power, environmental parameters swung outside of acceptable ranges, forcing growers to discard product.
NJ facility overview
This New Jersey CEA facility spans 58,000 square feet and is fed by a 480V, 8000A service, split into two 4000A services. The electrical infrastructure includes:
- Two 480V pad-mount transformers for utility power
- Outdoor switchgear
- Roof-mounted HVAC units and VFDs
- Complex lighting schedules with ~12-hour cycles Estimated 16,000kWh of daily consumption
The size and complexity of the load created real vulnerability to power quality issues, especially at the utility service entrance.
Installation of the permanent power quality monitor
To understand the root cause of HVAC and VFD issues, the facility team installed a permanent power quality monitor on one of the two 4,000A service feeds. The unit was mounted with:
- Voltage disconnects
- CT shunt assembly
- Integration with a master station for graphical user interface and remote monitoring via web interface
This setup allows facility engineers to:
- Continuously monitor utility feed conditions
- Capture waveform and RMS data in real time
- Proactively monitoring and analyze disturbances without waiting for failure
- Profile energy use by load and time of day
In the first two weeks of operation, the system captured normal operations and RMS startup events, confirming that load initiations weren’t to blame. The facility now has a clear baseline and is prepared to identify deviations before they lead to downtime.
Why the permanent power quality monitor works for CEA facilities
Here’s why a permanent PQ meter is a fit for controlled environment facilities:
The permanent meter, coupled with the master station, provides 24/7 data on:
- Voltage sags/swells
- Harmonics
- Frequency variations Energy utilization
Grid & load side visibility
This setup helps separate utility-side events from internal equipment issues — a key need in determining where disturbances originate for fast resolution.
Fast, actionable insight
The system offers waveform capture and automated analysis. Site engineers don’t need to sift through raw data to understand what happened.
Energy profiling
CEA facilities often operate on tight margins. The permanent meter enables:
- Demand, kWh and other tracking
- Load pattern analysis
- Lighting schedule verification
Scalable & future-ready
As the N.J. CEA site expands, a second PQ meter will be added to the remaining 4,000A feed. The system’s modular design and web interface support multi-site deployment and long-term scalability.
Adopting a proactive monitoring approach
Power quality problems can be sneaky yield killers in indoor cultivation facilities. Failures in HVAC, VFDs, and other systems can damage crops before anyone notices. By installing the permanent PQ meter and master monitoring station, this facility moved from reacting to equipment failures to proactively monitoring the health of its electrical infrastructure. They experienced:
- Greater confidence in environmental control
- Better decision-making using power profile data Reduced risk of batch loss due to unknown power events
Get ahead of power problems
If you’re designing or running a CEA facility for high value crops, you will want to be as proactive as possible about PQ issues. A permanent PQ monitoring system solution can give you the insight to manage uptime and protect crop quality, improving energy efficiency with data you can trust.
Ross IgnallRoss Ignall
Ross Ignall is the Director of Business Development and Marketing at Dranetz Technologies, a GMC Instruments company, where he has more than two decades of experience in power monitoring and analysis. With a background in engineering and product management and a career focused on instrumentation, power quality and energy solutions, Ross has been instrumental in building the GMC Instruments brand Dranetz. He works closely with engineers, utilities, and facility teams to align technology with real-world needs. A published author, IEEE and IEC committee member, and speaker in the fields of instrumentation, power quality, and demand/energy, he is a trusted resource in helping organizations take a smarter, data-driven approach to power system reliability. Ross can be reached at [email protected].
Related
Power Generation System For Factory
