Ethernet switch
Designed to mount on the outside of a control panel, the GracePort unmanaged Ethernet switch is available with unlimited combinations of outlets, data interfaces, and customer logos and text
Designed to mount on the outside of a control panel, the GracePort unmanaged Ethernet switch is available with unlimited combinations of outlets, data interfaces, and customer logos and text. Offered in UL Type 12, 4, and 4X, the product’s inside-out design locates four 10/100 Base-T(X) ports inside the panel and one port outside the panel. In addition, the reset button and the status LED's for all ports are functional from the outside of the panel. Other features include 9VDC to 24VDC input power and a 0°C to 60°C temperature rating.
Grace Engineered Products
For more information, visit www.graceport.com
