Arc flash protection
The FlashGard low-voltage motor control center (MCC) offers an insulated horizontal bus, an insulated labyrinth vertical bus, shutters to isolate the vertical bus when a unit is removed, and finger-safe components inside the units
March 12, 2007
The FlashGard low-voltage motor control center (MCC) offers an insulated horizontal bus, an insulated labyrinth vertical bus, shutters to isolate the vertical bus when a unit is removed, and finger-safe components inside the units. In addition, the product features an ARC Reduction Maintenance Switch that the company says reduces the time-available fault current. It also includes an applied breaker to reduce trip time during an arc flash.
Eaton
For more information, visit www.eaton.com.
